I agree with you on the point of intent, however the reason people fall victim to these scams is because they are susceptible to this sort of crash which can also happen due to innocent reasons on the part of the car in front.
I have little doubt that the driver in the OP is a scammer, however if a child had run out then the OP would have been blamed for the accident with no comeback at all (technically the fault would be on the child though blame is never going to follow, not in this day and age) and thus regardless of the other driver's intentions the OP needs to learn from this and be more careful next time.
That is a really annoying one, there is no "suckering" involved as it'll get you even if you do sit far enough back that you can see both wheels touch the road. It's also pretty much impossible to prove without witnesses, also in some cars, with certain driving styles, it's pretty easy to select reverse instead of 1st without realising so it may not even be intentional, and if it's an old duffer driving they may not have even noticed that they've done it and protest their innocence all the way.
If you're in a queue at the lights and you see reverse lights come on ahead of you, I would suggest you back off and hope the guy behind you does the same, beep your horn or take a picture (not with a mobile phone obviously, that would be illegal)
The fact that all this goes on is why as soon as I've got the Car PC re-installed into my Nissan, I'll be constantly recording video footage of my travels (deleted after 15 minutes) as we still haven't touched the other common scam where someone just pulls in front of you then slams on in a pre determined location where all their mates are hanging out on the street corner to be witnesses.
