So 1066/800 = MHz speed? Is that right? This would be no good then?;
Patriot Viper 4GB (2x2GB) PC3-10666 1333MHz
http://www.overclockers.co.uk/showproduct.php?prodid=MY-019-PA&groupid=701&catid=8&subcat=1387
I can't actually find any DDR3 RAM on OcUK that runs at 800/1066 MHz.
Sounds good. Will the BIOS automatically take care of the settings if I have it set this way? I don't do the overclock thing. I usually just let the mobo/BIOS take care of thingsYou can underclock the DDR3 to 800/1066MHz settings.
If/when you upgrade your CPU (or clock your present one) you could utilise the higher frequencies/settings.
