cant do "save as" on apple trailers
28 Jul 2004
llanelli , south wales
using my new media centre pc ... been adding my old programmes together on pc , but got a pronlem when i want to save a movie trailer from the apple site.
i got my version straight with a combi version of itunes and for some reason i can no longer save the trailers , which is a real pain as i like doing that. says options only in pro version
its apple quicktime 7.6.4 . i can do it fien on other pc but this new build i cant ... i'm idoing something wrong ?
Zom
Zom
18 Oct 2002
You must have Quicktime Pro installed on the other PC.
16 May 2005
Cold waters
That's hilarious.
The links to the .mov files are in the source of the web page. If they have checks on the referrer, I'm sure you could mock it with curl, wget or similar.
3 Aug 2005
UK
That's hilarious.
We have a winrar. Here's the manual method of doing things:
Take the trailer for Fame (available here) as an example. I can't remember what the equivalent command is on Windows, but on OS X it is possible to run the curl command on the URL for the trailer file provided on the website (in this example the 720p trailer) in Terminal. The command will be as follows:
Code:
curl http://movies.apple.com/movies/mgm/fame/fame-tlr2_720p.mov
and the following will be the returned in the Terminal window:
Code:
OmoovGrmra?rmda'rdrfurl fame-tlr2_h720p.movrmdr
After so many times doing this you realise the trick is to insert an "h" before the resolution designator, i.e. "720p" becomes "h720p". Recently the movie trailers page was also placed in the "movies.apple.com" subdomain, but the actual trailer files are not on a subdomain.
Remove the subdomain, add an "h" before the resolution designator, and run it through curl again with the -O switch (i.e. curl -O) as follows:
Code:
curl -O http://[b]www.[/b]apple.com/movies/mgm/fame/fame-tlr2_[b]h[/b]720p.mov
There you have it. The actual trailer file will start downloading.
Have a great day.
