£250 Spec Me
16 Sep 2009
Hey Guys,I am looking for a new pc after recently going to a laptop and missing the performance i used to have in games.
What I Have:
22'' LCD Monitor
Logitech Wave
Microsoft Habu
Thermaltake TR2 550W Power Supply
Seagate SATA 250GB
Samsung DVD Drive
What I Will Need:
Cpu
Ram
Motherboard
I havent added a gfx card to the budget so leave that for now because i will wait for the price drop in 4890s e.t.c.
It Will Be Strictly Gaming PC With A Bit Of PhotoShop And Solidworks so i am looking along the lines of Quad (Athlon 620 E.T.C)
Please try to save money were possible so i can have more to spend on a gfx card.
12 Mar 2009
For just a CPU/mobo/RAM in that budget I would get this:
AMD Phenom II X3 Tri Core 720 Black Edition 2.80GHz (Socket AM3) - Retail £97.99
(£85.21)
Gigabyte GA-MA785GT-UD3H AMD 785G (Socket AM3) PCI-Express DDR3 Motherboard £76.99
(£66.95)
OCZ Reaper 4GB (2x2GB) DDR3 PC3-10666C6 1333MHz Dual Channel (OCZ3RPR13334GKK) £60.00
(£52.17)
Sub Total : £204.33
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 15% VAT : £32.07
Total : £245.90
I would pick up if you're near the store too, will save you £9.50!
7 Jul 2009
Newcastle/Aberdeen
It is possible to unlock the 720, or the 550 BE (or indeed the Sempron 140) to a quad if necasary... and if you're lucky. Besides, Athlon X4s are great mainstream chips but the L3 Cache on the 720 pretty much makes up the difference.
OP
16 Sep 2009
Ok but its cheaper than the 720 so to me it makes more sense to go with the quad even if it does suffer a bit with no l3 cache,Also is it worth me going ddr3 for my needs or not?
12 Mar 2009
720 BE should outstrip the Athlon, that lack L3 cache really hurts it for some applications. I would get DDR3 as the prices between the 2 are quite close so you might aswell have the more future-proof and faster stuff in my opinion. Also the 720 clocks very happily if you're into that kind of thing :D
Permabanned
15 Nov 2008
The 720 is better for gaming, have a read of this article form anandtech if you want, if you were doing any sort of encoding/rendering then the lower powered quad may help, but for gaming the 720 is the way to go, theres still very few games that use more than 2 cores (less than 1%)
OP
16 Sep 2009
Having looked at that review i think i will go with the 720 albeit a bit more expensive its usually 'This Week Only'. Thanks for posting that up 95therifles
I think i will be best off getting a 785g motherboard which ones do you guys reccommend atm the asus ones are looking good but as always i would like other opinions.
3 Feb 2009
The 720 is definitely faster in most apps. The 860 might help with heavy multitasking, but for any individual task the x3 is better. :)
12 Mar 2009
I still recommend the Gigabyte GA-MA785GMT-UD2H AMD 785G (Socket AM3) PCI-Express DDR3 Motherboard at £73.99 inc VAT board I posted originally :)
