- 17 Dec 2004
- Crawley, WEST SUSSEX
I too usually hit the . button when im typing in portrait mode, but after using the phone in landscape mode now its dead easy to type and not hit the wrong key
you got a link to it please mate?
It should be fine to put the official rom on it, only Orange and T-Mob seem to make you unable to update roms without rooting/waiting for a new rom from provider.
The Orange rom update is available on the HTC website without the need for rooting.
is it any good ? im finding my battery dies really quickly since updating my rom to a custom one.
) and mine is running fine, I get quite a while from my battery. But then I've turned off all data stuff, so only connects to WiFi/Data when I want it to, and have installed App Killer to turn off all extra apps from the background.It is indeed and by the looks of the number on it, it's older than the HTC one I have on the phone so I'm not bothering with it.
I'll be rooting and installing other roms anyway.
Really?
I'm running the HTC one from MoDaCo (unmodified official release but actually installs) and mine is running fine, I get quite a while from my battery. But then I've turned off all data stuff, so only connects to WiFi/Data when I want it to, and have installed App Killer to turn off all extra apps from the background.
invader how did you get it to only use data/wireless when it needs to?
ideally i want it to check email every hours by turning on wifi, looking for a wifi network then if it cant find that turning on data to retrieve. after it is does to then turn them both off?
also, getting it to do the same thing when i am browsing would be good too.
at the moment i have the widgets on my home screen for manually activating them.
im running the modaco rom aswell, and i charged my phone during the night and by 11 it was down to 50% i had all the mobile conections turned off, no wifi or gps either, i then chraged it in the van and its lasting better now![]()
Maybe i have a duff battery .
ta invader.
the last thing i need to do is work out how to get delivery reports for messages. The old sony ericsson t68s had a great screen notification that popped up once the mesage had been delivered. I wonder if the htc can do this too![]()
Cheers for the reply
I,ve spoken to them on their live help on the website and they have said it would be unbranded/unlocked.
Now I need to decide on which tariff to go for and I'm set.
