USB hub to complement Xbox 360?
Commissario
16 Oct 2002
In the radio shack
I know that any USB hub will work with an Xbox 360 and in fact I have a small one connected but it doesn't particularly blend in with the console, the USB ports are all on the back and it's all a bit rubbish.
Is there a USB hub that's designed to go with a 360 in that it will sit nicely next to the console, have the ports on the front and just look 'right'? I have an original Xbox core with a nail on hard drive.
I'm in the process of a tidy up under the telly and just want it to all go together.
26 Dec 2004
Sweatshop.
how would that match?
this:
26 Dec 2004
Sweatshop.
That's about the best I found as well, it's not attractive!
Yes. One of them has never worked, but I didn't try and use it for ages so by the time I realised, I think it was out of warranty.
how about one of the attachments for the xbox feek, the back panels that clip on have numerous usb ports :)
