Done
Ok Thanks, so Im right in thinking that my card should arrive on thursday now?
Done
, so looks like a 5850 for me,a s ive just got this case so don't fancy hacking the drive cage to bits
screw it, could you change my 5850 back to the powercolor (which i had originally)
they better be good because ive heard bad things about them![]()
are those openings at the end of the card its twin exhausts...if so, this is blowing directly into my lower intake fan. ....... it's only 6'' away
Order No: OC884414
Not waiting for possible ever for news on the sapphires
Eh, why has my order balance come to £406.62???
AFAIK the card sucks in air through those ports and then exhausts the hot air out of the back of the case.No mate there just decorative (not joking) as far as I know
You will want to watch out for clearance, this video card clocks in at a full 10.75" inches long to the edge of the red vents on the back. You can see a close-up of the top vents above, the air that escapes here is very hot and does exhaust into your case. If however, you have a side panel fan or fan on the back of the chassis near the expansion slots, it could potentially exhaust this hot air.
