Hi Folks,
I currently have a HTPC that I use as a freeview recorder/ bluray and HDD player. I have windows vista installed and use Vista media centre for everything except for HD media for which I use power dvd.
The pc is playing up a bit so I am going to wipe the operating system and reinstall but before I do I wanted to check if there was better software for me to use. Can I use Windows 7 trial and does it have a media centre? I'd eventually get the full version when I need to but I might try it out if it is in anyway better than vista.
Are there any open source OS's that are good for media players or any software that I can use instead of VMC ? It's a bit annoying having to switch between power dvd and VMC, can anything support Blu ray and HDDVD playback natively?
Thanks
Matt
Thanks
Matt
Am investing in a Blu-Ray drive soon, so will need to look in to that side of things, but I'll probably rip my BR to my fileserver anyway most of the time.
