QuickCam Pro 9000 + Win 7 7100
7 Nov 2004
Southampton/Oxford
Does anyone have the QuickCam Pro 9000 working with Win 7 perfectly? Need a web cam this week, read reviews on a few sites and hear good things about it as well as threads on OcUK, but not sure if it would work fine on W7, seeing my QuickCam Fusion does not work at all:confused:
I have what I think is buld 7232 (64-bit) and it works OK on that - I installed it while drunk however, and i think it needed some compatability mode tweeks to get working properly but I honestly can't remember - google aught to help with that.
IE it's not a fire-and-forget install but with a little fiddling it is fully functional - face tracking, autofocus etc all works perfectly.
Logitech's webcam drivers for W7 are a joke, mine worked fine for a while then decided it needed to re-install the drivers, then it told me there was no compatible driver. Trying compatibility settings caused me some major problems.
I now use a Microsoft webcam.
No such issues for me, despite multiple reboots, connects and disconnects while moving my hardware around.
Installing as the Administrator seems to be the answer for the 9000, this rings a bell for me, albeit a slightly blurry and unsteady one ;)
I just bought a Quickcam Pro 9000 (I like my toys) and downloaded the latest 64 bit vista software from Logitech's website. I installed it in 7264 (x64) as administrator and all the webcam features are running with no problems.
http://www.sevenforums.com/drivers/2079-logitech-quickcam-9000-pro-controls-missing.html
