I couldn't use data after installing the ROM without wiping first. Try to reinstall but wipe beforehand if you didn't already?
Yup, many times, is bloody annoying, may have to phone Orange I think.
I had this problem, installed the latest modaco rom and hey presto, no data connection.
All you need to do to solve it is to specify an APN, the original entry gets deleted with the new ROM.
settings>wireless controls>mobile network settings>access point names... press menu and then new APN.
Name it orange, and put "orangeinternet" as APN (without the quotations), leave the rest blank, save it and it should pick up the data connection pretty much straight away.
Hey I was just wondering if there was a way to get capital fm's on air to work on the hero? Ie listen to capital via their website? Would be great as its blocked at work.
I've just removed Rosie to see what its like.
Guide:-
http://forum.xda-developers.com/showthread.php?t=547658&highlight=space
edit- Not a massive difference to MCC 2.3.
What's rosie exactly?
tried modaco's 2.3 rom and it seems like it's faster, but the bad news is it has screwed up my texts in that i cant read them![]()
trouble is i'm now on windows 7 and can't get htc sync to work and retry updating the rom. have searched for a work around but nothing that worked. anyone any suggestions?
In case anyone is interested, I've just got a set of the HTC screen protectors. They seem ok for glare and have a nice smooth feel. They also seem as good as the screen for fingerprints etc. They come in a 2 pack and I paid a fiver delivered which seems better value than some other branded ones.
