Interesting stuff.
Could there become a point where you could run a computer simply from a GPU instead of having both a CPU and GPU? Thinking of the future of course.
Interesting stuff.
Well nVidia don't have an x86 license, so they can't produce anything that will be able to run windows without a traditional CPU.
They wont need one, they will run CPU and the GPU together in a co-processing model, simples![]()
hopefully nvidia see sense and port physx to opencl
Interesting stuff.
No, you'll always need both.
The CPU for fast serial tasks, and the GPU for parallel vector-type computations. They may well end up on the same piece of silicon, but there will always be a distrinction between the CPU-like and a GPU-like part.
The "holy grail" would be a compiler which can analyse user code, and efficiently determine which portions should be sent to what bit of hardware. This is a long long way away though, a long way behind the hardware. As it stands today, it takes a huge amount of skill to manually specify what should be sent to what device.
