so? crap tyres are crap regardless of tread![]()
Yes, no, indeed, or maybe perhaps.
Goodbye Susan.
King Pin Inclination (KPI) is the generally accepted term![]()
well thats cheap chinese tyres for you! i work at a car garage and we have countless people comming in saying they got new tyres but there cars slide all over the place (someone in a new VW passat) its always chinese tyres! no matter hot much tread they have, there rubbish. get some good italian tyres or similar. dont buy chinese, indonesian or tiwaneese tyres xD we usually are always requested to replace there brand new tyres as sometimes there that bad they say there cars are undriveable! marangonnoi is a really good tyre to fit to ur bmw xD we have a set on out bmw 540i 4.4 v8. they grip like mad!
How do you understeer at 10mph?![]()
I've done it beforewet roundabout with negative camber. Fortunately no one in the outside lane and I could take an earlier exit than intended..
Yes and no. Different tyres deal with wet roads differently.. obviously. But one set of tyres might have good dry performance but rubbish wet performance, while another set could have mediocre dry and mediocre wet performance - it's not as simple as saying 'these tyres are crap in the wet therefore they're crap' - as they may be very good in dry![]()
my brother had a 1.2 clio a while back and it came with seriously bad no brand tyres. no joke, you coudl exit a roundabout in second, put your foot down and the weedy little car would wheelspin all the way down the road
just imagine trying to stop the thing?!
^ It was a mist wet day, hadn't rained but drizzled all afternoon. Although cheap, the front two have thousands of miles worth of DRY miles left on them.
Only when a vehicle has king pins, which means some old classics and goods vehicles mainly. I can't think of any modern cars with king pins, therefore it's steering axis inclination![]()
ALL cars do this to some extent, it's caused by a combination of the castor angle and the "steering axis inclination" (SAI). Camber also changes with body roll to some extent (unless you have a live axle).
My grammar nazi head has just exploded...too many....there/they're/their errors........heeeeellllpppp.
well thats cheap chinese tyres for you! i work at a car garage and we have countless people comming in saying they got new tyres but there cars slide all over the place (someone in a new VW passat) its always chinese tyres! no matter hotmuch tread they have, there rubbish. get some good italian tyres or similar. dont buy chinese, indonesian or tiwaneese tyres xD we usually are always requested to replace there brand new tyres as sometimes there that bad they say there cars are undriveable! marangonnoi is a really good tyre to fit to ur bmw xD we have a set on out bmw 540i 4.4 v8. they grip like mad!
I've actually missed a few but I totally lost the will to live.
