- 28 Sep 2009
Purpose, to play a game in high quality across 3 monitors from 1 pci-express graphics card.
Any suggestions for a single PCI-EX graphics card that can output to 3 monitors at the same time?
I have seen some ATI X2 cards with 4 DVI connections, but to use all 4 connections, you have to disable the crossfire, which kinda defeats the purpose as they are meant for gaming at the same time. If using 2 x nvidia cards, you also have to disable SLI to use the outputs on both cards
I have seen some matrox triplehead2go options, but they only support vga and also have a low resolution which is pointless
For al those tecchies out there, excuse my simple language, but it makes sense to me anyway
