Hi,
I have aqquired a hardware firewall (SonicWall TZ150) which I am configuring on my home network, however I am having a few problems when working alongside my Netgear DG834GT router.
At the moment the layout is:
Workstations (192.169.0.0/24) > SonicWall TZ150 (LANIP 192.168.0.100, WAN IP 192.168.0.100, Default gateway is the netgear IP 192.168.0.1) > Netgear DG834GT Router and access point (LANIP 192.168.0.1, WANIP = xxx.xxx.xxx.xxx) > Internet
I want the router to be used as the router obviously, the modem and the access point as without this, the laptops in my house can not use wireless.
I have connected it up as per below (the wired connections using the switch on the TZ150, the wireless is outside of the protected zone). If i connect a pc up to the TZ150, I can ping the firewall, but cannot access the web or ping my router (192.168.0.1), how would I get this to work? would I have to turn off NAT, DHCP and firewall off on my netgear router resulting in the gateway address of the TZ150 pointing to the netgear and the TZ150 acting as the DHCP server for the rest of my LAN?
Any help appriciated
Thanks
Thanks
