A Boost to Wireless?
19 Dec 2006
Saudi Arabia né Donegal
Hello all,
Bit of a spec me thread as I'm looking for the best way to boost a wireless signal, would a wireless repeater be what I'm looking for and, if so, what one. If I were feeling a bit braver would I be better off buying a dd wrt compatible router and flashing that for this capability.
Unfortunately running cable isn't an option, nor is modifying the original router in any way.
Thanks in advance,
Antar.
26 Feb 2009
Exeter
Depends on where the router is positioned - if its central in your house then a repeater wont help much unless you only want a boost in one direction.
I'd get another router with removable antennas and a couple of decent high gain antennas to go on it.
OP
19 Dec 2006
I don't really want to be spending too much on equipment that I can't take away with me. I'm trying to improve reception on my end from the landlords broadband (don't worry, it's all above board as I have permission, and the password). Therefore movement or modification of the original router is out of the question.
