In what country?
You NEVER see any BX, CX or XMs around!
Ok so the UK is a bit different than here, sorry
In what country?
My old flatmate has a BX diesel with about 250k on the clock. Drives it from Bristol to France all the time. I bought and sold a Xantia estate auto recently. Drove absolutely fine.
Depends on what you mean by 'breaking down'. If you mean, leaving you stranded by the side of the motorway, then apart from Alfa Romeos (which simply blow up), very few cars nowadays leave you stranded by the side of the motorway unless they've been mechanically neglected.
For pure reliable though, it will be the Honda, then the Toyota.
[TW]Fox;15022038 said:I dont really see how a classified ad site from another country shows willingness to pay.
Snowdog v Tute, this could be amusing.
Based on that, every Citroen ever made is perfectly fine. Righto.
Breaking down = anything going wrong with it.
I don't think that in the real world a Corolla would be any better for reliability than a Focus - even the survey says there's a 4% difference which is well within the realms of error.
Wow, is everyone ratty today after getting up early for the Grand Prix or something?! Calm down...
An 05 plate C4 is perfectly good car if low running costs and reliability are the objectives, not significantly better or worse than a similar Focus.
Repeated ingress of saline water into the connections to the Electronic Control Unit for the Anti- Lock Braking system may eventually result in a short circuit that could cause a fire in the engine compartment.
This concern relates to right hand drive vehicles only. There may cases of the brake linkage lever being defectively assembled, which may result in a loss of braking efficiency.
There is a possibility that a seepage of brake fluid may occur at the union between the rear flexi hose and the metal brake pipes. This would eventually lead to the illumination of the low fluid warning lamp, which if left would result in longer brake pedal travel and reduced effectiveness of the brakes.
Why not? Based on the way you drive, an Avensis does 99% of everything your car does. Cheaper to run and more reliable too!![]()
Except for the 12,220 C4s built between 01/01/2004 and 31/12/2005 that were recalled due to them being at serious risk of catching fire.
The 6,772 built between 01/09/2005 and 22/11/2005 recalled due to braking issues
The 6,906 built between 01/06/2005 and 30/09/2005 whcih were recalled due to possible brake fluid leaks.
More recalls involve 25,000 cars being recalled due to the possibility of the airbag not going off in a frontal impact. Over 75,000 recalled with ABS/ESP issues. See for yourself: http://www.vosa.gov.uk/vosa/apps/re...or the date range 01/1/1992 to 01/12/2009&tx=
I would check to ensure any car would have had the work done, if you do go for a C4.
Now do exactly the same search for Focus recalls and post the results.
I have. No recalls are as serious as water leaking into vital safety systems such as ABS, ESP and airbags and causing them to fail. The most major recall on the Focus was for an overheating/failing wiper motor. The effects 65,000 cars made in two years.
When you consider the Focus sells in much much higher numbers, a lower percentage of cars will be affected.
Post all the details then so that we can all see then and make up our own minds.
18 29/07/2008 R/2008/113 FORD FORD FOCUS, C-MAX, FOCUS CC failure of power steering hose could result in an engine bay fire 02/04/2008 15/05/2008
19 29/07/2008 R/2008/113 FORD FORD FOCUS, C-MAX, FOCUS CC failure of power steering hose could result in an engine bay fire 02/04/2008 15/05/2008
20 08/04/2009 R/2009/016 FORD FOCUS risk of fire 01/06/2006 25/01/2007
21/09/2009 R/2009/071 FORD Focus risk of fire 20/02/2004 31/05/2006
Pretty serious problems in there...28/06/1999 R/1999/051 FORD Focus possible short circuit in alternator Various 01/06/1998 31/03/1999
2 07/10/1999 R/1999/084 FORD Focus, Mondeo and Cougar door latch concern WB, WR & WA 03/09/1998 18/11/1998
3 20/03/2000 R/2000/046 FORD Focus (1.6) engine may lose power Various 01/01/1999 31/01/2000
In what country?
The MK5 Golf is BLAND and the C4 isn't very nice and you would have to be a bit mad to buy one over a Golf, Focus or Corrola.
