These 100hz,200hz TVs - are they not risking unsyncing sound?
15 Nov 2003
Marlow
If my (noddy) understanding of the new TVs is correct, they basically interpolate between frames? So instead of playing 24 frames a second, they inject additional fill in frames between them.
But surely this means they are one frame beind the true one?
ie: The TV is sent frame 1, but the TV does not display frame 1 unti frame 2 is received, and so on... Now if the audio is being pushed out to an amp and getting played immediately, couldn't the audio be ahead of the images on the TV?
Or is this time delay so minute it's of no concern?
Or is my understanding of these TVs wrong?
RSR
RSR
17 Aug 2006
Nope, If every thing is running HDMI 1.3 It has audio sync as part of the specs.
Version 1.3
HDMI 1.3 was released June 22, 2006 and increased the single-link bandwidth to 340 MHz (10.2 Gbit/s. It optionally supports Deep Color, with 30-bit, 36-bit, and 48-bit xvYCC, sRGB, or YCbCr, compared to 24-bit sRGB or YCbCr in previous HDMI versions. It also optionally supports output of Dolby TrueHD and DTS-HD Master Audio streams for external decoding by AV receivers. It incorporates automatic audio syncing (audio video sync) capability. It defined cable Categories 1 and 2, with Category 1 cable being tested up to 74.25 MHz and Category 2 being tested up to 340 MHz. It also added the new Type C miniconnector for portable devices. HDMI 1.3a was released on November 10, 2006 and had Cable and Sink modifications for Type C, source termination recommendations, and removed undershoot and maximum rise/fall time limits It also changed CEC capacitance limits, clarified sRGB video quantization range, and CEC commands for timer control were brought back in an altered form, with audio control commands added. HDMI 1.3b was released on March 26, 2007 and added HDMI compliance testing revisions. HDMI 1.3b has no effect on HDMI features, functions, or performance, since the testing is for products based on the HDMI 1.3a specification. HDMI 1.3b1 was released on November 9, 2007 and added HDMI compliance testing revisions, which added testing requirements for the HDMI Type C miniconnector. HDMI 1.3b1 has no effect on HDMI features, functions, or performance, since the testing is for products based on the HDMI 1.3a specification. HDMI 1.3c was released on August 25, 2008 and added HDMI compliance testing revisions, which changed testing requirements for active HDMI cables. HDMI 1.3c has no effect on HDMI features, functions, or performance, since the testing is for products based on the HDMI 1.3a specification.
OP
15 Nov 2003
Marlow
Version 1.3
But, in my case, and a lot of peoples, I suspect the HDMI goes straight to a TV, and audio (via optical for example) goes to an amp?
For most people it's the simpler more friendly wiring solution...
Caporegime
21 Oct 2002
Here
Its a valid question, and is the same reason I think these 'smoothing' technologys can introdcue lag in gaming. You need to a delay to allow the processing to work due to the reasons you have mention
However on the internal stuff I can only assume the TV corrects for the sound delay, ive never noticed any issues when using these 100hz modes on TVs i have had experience of
Cheers
OP
15 Nov 2003
Marlow
Cheers
Well, I'm not informed enough to know if my assumption of the process is correct. But if it is then the system has to be putting in a 1/25th of a second delay?
Now if anyone has audio going seperately to an amp, then would this 1/25th of a second delay actually be an issue? Can you see/notice a 1/25th of a second mis-match? I doubt it?
RSR
RSR
17 Aug 2006
Ahh i see what you mean now, Ive not noticed with my setup. However, i am only running HDMI. Its a good vaild question though.
OP
15 Nov 2003
Marlow
Infact I don't see how HDMI changes the question.
Frame 1 goes out with audio for it... Followed by frame 2 and it's audio for it (OK I know they're not bound togethor like that, but for the sake of example let's assume that's the case)...
They go into your amp, and you amp plays the audio for frame 1 and passed the video to your TV... which... doesn't display it until it's received frame 2. Meanwhile your audio has now moved onto frame 2...
So the video is still lagging behind a frame?
So the fact you've not noticed anything, and assuming you have one of these 100hz/200hz sets, maybe this shows the delays is so small, there is no issue :) And I'm just wasting everyones time :)
RSR
RSR
17 Aug 2006
I do have a 200Hz set and ive not noticed a lag in gaming / blurays. However, some times Sky can be a little off but this was doing it on my old set as well.
However, as i said before as i am runnig a complete HDMI 1.3 setup, i believe this should play a part in the audio sync problems. Ive not tryed any of the inputs via a optical / coax cable though.
Andy
OP
15 Nov 2003
Marlow
Andy
But all your players/sources will do it push out video and audio togethor, be it down the same wire (HDMI) or split up (HDMI and optical). Your TV (we think) will then put in a 1/25th of a second delay on the video...
So the fact you're not seeing any sync issues suggests either we're miss understanding the techonology and this no video delay, or it's so tiny you just don't notice it... (My guess is the latter)
3 Aug 2003
Plymouth, UK
I didnt think you could output audio over HDMI with Sky??? Only audio out to amp i was aware of is optical (as i have with my Sky HD)
Cant comment on the delay issues as dont hav ethe 100hz witchcraft going on
RSR
RSR
17 Aug 2006
You can. However, its just 2ch output. You need to use the optical for 5.1 etc..
5 Jan 2003
West Midlands
Virtually all AV amps, many DVD & BluRay players, and SkyHD STB include options to add delay to the SP/DIF digital output, so if you notice any lip sync problems, its easy to correct.
Sky's the biggest offender, as I have noticed that if the signal quality from the disk isnt pretty much maxed out (strength 50% or better, + signal quality maxed) then the sound will often go out of sync with the program, especially on some of the lower bandwidth channels.
Delay adjustment on amps and/or AV replay gear is even more important with TV's that do any form of digital enhancement to the picture, as it can add quite a bit of delay. Early plasma TV's could be as much as a second "behind" due to all the processing that was required to get the picture onscreen. Its not really a huge problem with more recent TV's but out of sync audio can still rear its ugly head sometimes.
10 Apr 2004
I think your getting confused here.
The way I understand it is that it is displaying frame 1 twice, then frame 2 at the correct time, etc.
100hz has a period of 0.01 seconds, while 50hz is 0.02 seconds. So time between frames on a 50Hz TV is 0.02 seconds.
On a 100hz TV it's still 0.02 seconds but frame 1 has been displayed twice in that time. (0.01 seconds between updates)
From what I think you think it does means that the sound would get more and more out of sync, and as it doesn't its not how it works. (It would be one frame, then two frames then three frames behind and so on?)
Basically don't worry about it :p
29 Jul 2004
Somerset
It actually generates an 'average' image in between the two frames, to give the impression of high fps or smoother playback.
In FFDShow I buffer 24 frames ahead with my frame doubling interpolation script, and I can't say I've had a problem with audio sync. Both with HDMI Audio & Video, and HDMI Video/Optical Audio.
I'm sure theres some very clever sync timers and things talking to each other, and jitter correction in between.
10 Apr 2004
Interesting.
In that case its only ever one frame behind, which is hardly an issue at 0.02 seconds :p
OP
15 Nov 2003
Marlow
Yes, but it could display 1000 generated images between the real frame 1 and the real frame 2, but it CANT do that until it's received frame 1 AND frame 2. So it is alway has to lag behind the signal/transmission by 1 frame.
Assume 24FPS, that means about 0.042 of a second...
