hi all, in the middle of a new build, tower is a new nzxt guardian 921, front has 3 5.25" bays, one is been occupied by a dvd/lightscribe, the other 2 are redundant.
kama bay: http://www.overclockers.co.uk/showproduct.php?prodid=SY-000-SY
anyway, although im sure the kama bay requires 3 bays, behind the front 2 is space to fit a 120mm fan in no problem. what i need to know is does the kama bay need to be pushed all the way in, or will it gladly sit in there even if it sticks out the back a bit?
just looking for some extra air intake over the ram etc + use the space up, dont need any other optical drives or fan controllers either, so makes sense.
Cheers
Cheers
