voltage required for 4.0 & 4.2Ghz on a D0 920
16 Sep 2009
Milton Keynes, Bucks
Hi guys, just wondering what sort of voltages you guys are needing to use for a stable 4.0Ghz and 4.2Ghz?
Also, another question, does the bclk and multiplier have any effect on the voltage required if the result is the same? E.g. 191x21 vs 200x20?
1.28V on windows desktop, 200x20, hyperthreading on, turbo off. Probably stable but not very tested yet.
200x20 tends to need more voltage than 191x21.
I see, im currently at just over 1.3V, seems a little high compared to you guys.. i wonder if i can drop it down without bsods :)
Hmm perhaps im missing something...
I've set my my qpi voltage, pll and my clock skew at 1.65, 900mv and 100ps respectively, but to hit 200x20 im needing to push my cpu voltage up to over 1.3 to get into windows and im still getting bsods in prime at over 1.35v.
any ideas?
If you're actually pushing 1.65V qpi its important that you stop doing so, that's about 0.3V too high. I think that's in the region where xs discovered processors dying after a couple of days.
Hmmm this is what the XMP settings pushed it to, i may be mistaken and its 1.35qpi though.. probably is 1.35 come to think of it.. and ive mixed myself up with dram voltage which is 1.66
I guess I've got a weak chip then :(
Which is strange since I could run 3.4Ghz safely at 1.15V.. cpuz reports 2.6ghz at 1.224V in contrast..
Maybe I'm missing something, or not hitting the right setting, any ideas?
Also, what does PLL voltage actually do?
