- 19 Jul 2007
- notts , uk
when are the 5770's being released ? , whats the full specs of this card ?
I would also expect a 128bit bus to be honest but like you say the ROP count will be interesting. Again I would expect it to be 16 to keep die size down for max profitability but you never know they might just squeeze in 24, which would surely give ATi a mainstream monster as long as it isn't bandwidth bottlenecked.
Not about die size, they are the full 2.15billion transistors as a 5870, just with failed parts turned off. Thats why, its possible it has 32, but very unlikely, if it did, the numbers it could do would be very very interesting indeed, the question really is how many have been cut. We can't say at all which parts of the core are doing worst with the TSMC process, or if its random so till we see final specs we're just guessing. THe site that has it listed for sale(due in today) says its 4.8Ghz mem, 850mhz core, 1GB mem and 128mbit bus, which all sounds plausible, but doesn't list rops.
So tempted to pick one up on the hope they are good, and maybe just to play with something new, though I had been planning on a 5850 being bought today.
It seems to be heavily implied by AMD's marketing that it's a separate core:
http://anandtech.com/video/showdoc.aspx?i=3643&p=3
I'd also say it's evidenced by the fact that they say they need a cheaper to produce core, disabling SIMDs on Cypress does not achieve that - it just makes it run slower. It also kind of defies AMD's recent naming schemes to name two like chips completely differently (with the exception of the X2 parts). Also I've heard the figure 1.3 billion transistors for the Juniper part, which would fall about in line with the configurations we've seen.
Also, if this picture really is of Juniper, then judging by the bracket, the core is physically far smaller:
http://www.techpowerup.com/?102018
Makes you went to sell the 5870 and crossfire two 5770's.
Theoretically they should be faster as they have more shaders and run at higher clocks, memory bandwidth should be lower (due to 128bit vs 256bit bus), but not considerably so as their memory clock is far higher (4.8Ghz vs 3.6GHz).
