Mass debate at work.
Man of Honour
17 Feb 2003
Chelmsford
My mind works very different to some it would seem.. :D
Anyway, I thought the cold would come straight off the mains. We have a combi and can't say I notice any difference... then iagain I have no taste.. only bad taste!
17 Jan 2005
Liverpool
Its not usually acceptable to have a "mass debate" at work.. If you do though, make sure you do it in the toilets and wash your hands afterwards! :p
On the subject of water though.. If the pipes are different/older it can taste different. My old house had an extension built with new bathroom and the water was so much nicer there than anywhere else in the house due to the new pipes! :)
24 Jun 2004
Manchester
Why noy stop arguing and put it to the test?
Get a few bottles filled with water from "upstairs" and "downstairs". Label them in code, and have only you know the meaning. Then do a blind taste test (administered by someone else). If people can tell the difference, then you have your answer. If not, it's all psychological.
Yeah it's effort, but there's really no other way to settle it.
Permabanned
28 Dec 2007
:D
Caporegime
4 Jul 2004
Yeah, and also give them the same water twice, and see if they think it's the same. If not, pour it all over them for being dirty at work.
SamuraiTortoise
S
SamuraiTortoise
We have a combi boiler installed and the water tastes identical on each of the three floors. It also has a nice cloudiness to it. Can only drink water from the water coolers as this is a million times better - even though it's the same water, just filtered and cooled.
Man of Honour
27 Sep 2004
Glasgow
Logically even if the water all comes from the same tank it could be possible depending on what material the pipes are made out of I suppose but most likely I'd expect the difference to be a) psychosomatic or b) because one tap has a greater run to it so the water has been sitting in the pipe for longer.
