DirectX
14 Sep 2009
S.Oxon
Hi, I'm getting a PC with a crappy GPU until i upgrade about a monh or so later.
The GPU is DirectX 9(6200GS)
Will this be okay for running Windows 7 with, or should I get one with DirectX 10, but I hear it should be okay as that only applies to games.
would be a waste of money to get a DX10 card just for the OS...even to buy one for a game i would say but thats debatable :p
You won't get aero desktop if that bothers you, you need a DX10 compliant card.
are you sure about that ?
fairly sure i had it running fine prior to a 8800gts and thats a DX9 card
it probably wont run with every Dx9 card as you probably need certain features and a certain amount of memory but that requiring a DX10 isnt true as far i recall.
could be wrong tho my memory is a bit poor at times :p
i'm not bothered about the aero for 30 days :)
This is the system by the way :)
