Quick question about this 20-30min workout: The Spartan Run
2 Jan 2009
Aus
So i've been wanting to attempt doing a Spartan Run for a while but have been a bit confused; it comes under the section "The best 20 - 30 min workouts" and here it is....
Spartan Run:
- Run 1 mile
- 100 pushups in as few sets as possible
- 100 crunches
- Run 1 mile
- 75 pushups in as few sets as possible
- 75 crunches
- Run 1 mile
- 50 pushups in as few sets as possible
- 50 crunches
This can't be done in 20 - 30 minutes can it? Seen as the standard army training run of 1.5miles is to be achieved in under 10mins 30 (for my age).
Or am i just looking at it wrong and it should be looked at as 3 different fitness levels so like:
if you're just starting out or not very fit go for
- Run 1 mile
- 50 crunches
and then eventually progress up to:
- Run 1 mile
- 100 crunches
Thanks,
Flare
think its the whole thing, easily doable (for some people) 3mile run can be done in under 20, 250 pushups in 5 minutes and the crunches quicker then 5 minutes
can't be a 20-30 min workout if you just running 1 mile, for those not so fit i guess they aim for 30 min rather than super fit people aiming for 20 (that would be pretty crazy speed to do that) Looks hard anyways
Yeah, having a bit more of a think about it i suppose it is doable. I just showed my friend who is a machine and he said the distance ran should be 1.5miles OR do more between each mile. damn people like him! :p
1.5 miles 3 times in 20 minutes would mean an average speed of 13.5 mph (22 kph), machine or not that is a very fast sustained speed considering a 4 minute mile requires an average speed of 15 mph. (In other words, I doubt he could actually do it).
I'm in no doubt!
Maybe he got a 'bit' ahead of himself.. :p
Still, I'm game enough to try it :D. Can't do until early next week but I'll give it a go.
Lets start a friendly SA book on how long it will take platypus to do the Half Hour Spartan Run.
I will take 52 minutes :p.
Id change the Crunches to Sit ups.
AFAIK Crunches are no good for you back at all =/
Is that because sit ups are often not done correctly or are they just bad for the back?
They put large amounts of pressure on your lower back, probably not a problem if you dont have any back problems but I imagine prolonged use could make existing conditions worse
I do the Military Sit ups as in this video
http://www.defencejobs.gov.au/lifestyleoffitness/tips.aspx
I was told by a Personal trainer and Lecture from the AIF (Australian Institute of Fitness) that crunches put huge amounts of pressure on your back
