Ubunutu Server - Unlocking the disk
1 Dec 2004
S.Wales
Hi,
Does anyone know if this should be pushed to the side or not, iv selected the option for security without thinking of remote reboots. When it comes back up I have to enter a password.
Whats the best way to deal with this so I have no stress rebooting remotely
Not sure if I understand what you're talking about.
Have you encrypted the disk? That will ask you for a passphrase on boot. If that's the case I think you need to use cryptsetup to remove the encryption. Ensure you backup first ;)
What exactly do I need to back up and what shall I use to back up? is there an easier way of removing the encryption?
Use MondoRescue to backup whatever files you want to an iso (as an example).
There is no easier way of removing the encryption from what I know.
I did a clean install to solve this, luckily there wasnt much on the server to begin with so wasnt a great loss, just time ;)
