- 15 Feb 2009
- Bristol
Just looking at the TU60 lighter because it's on sale for £7.50 atm. But has anyone used one or have one? And is it any good?
Where are they £7.50?
-edit-found it![]()
I used to have one, it was quite good especially in the wind. It did use gas at an alarming rate though.
And no they don't leak, they're gas, zippos are fluid which is why the leak, it just evaporates out of the gaps.
Can't go wrong with zippos though, I have several and they're corking. Just need filling up quite often because of the evaporation. About once a week, maybe two weeks at a big stretch.
Where? I'm not having much luck.![]()
I won't use it too much so it should be ok.
Does it take butane gas? Any butane gas refiller will do if so?.
