Hi, i would like to have some help on overclocking my core i7 920 D0 to the fastest speed possible which am hoping will be 4ghz plus also these are the specs i have which i hope these will help you to assist me.
here are all the options i use at the moment which seems to be the best i got so far on my own. i have had it at 4 ghz but not stable so am asking you guys to help me
CPU Clock Ratio [20 X]
CPU Frequency 3.20GHz(160x20)
QPI Link Speed [x36]
QPI Link Speed(MT) 5.76GHz
Base Clock(BCLK) Control [Enabled]
BCLK Frequency(Mhz) [160]
Performance Enhance [Standard]
Extreme Memory Profile(X.M.P.) [Disabled]
System Memory Multiplier (SPD) [10.0]
Memory Frequency(Mhz) 1600
DRAM Timing Selectable (SPD) [Expert]
Profile DDR Voltage 1.5V
Profile QPI Voltage 1.175V
>>>>> Channel A
CAS Latency Time 8 [ 8]
tRCD 8 [ 8]
tRP 8 [ 8]
tRAS 20 [ 24]
Command Rate(CMD) 1 [Auto]
>>>>> Channel B
tRCD 8 [ 8]
tRP 8 [ 8]
tRAS 20 [ 24]
>>>>> Channel C
tRCD 8 [ 8]
tRP 8 [ 8]
tRAS 20 [ 24]
Load-Line Calibration [Disabled]
CPU Vcore 1.23125V [1.30000V]
QPI/Vtt Voltage 1.175V [1.175V]
IOH Core 1.100V [1.100V]
DRAM Voltage 1.500V [1.600V]
CPU: Intel Core i7 920 D0 (160x21 3.36ghz with ht on and turbo on )
Cooler: Corsair Hydro H50
Motherboard: Gigabyte GA-EX58-UD3R v1.0 (bios is f8d )
Ram: Corsair Dominator 3GB (3x1GB) (it can run at 1867 mhz with x.m.p on) only running @ 1600mhz 8-8-8-24 1T
Case : Lancool k58
>>>>> Channel A
tRCD 8 [ 8]
tRP 8 [ 8]
tRAS 20 [ 24]
>>>>> Channel B
tRCD 8 [ 8]
tRP 8 [ 8]
tRAS 20 [ 24]
>>>>> Channel C
tRCD 8 [ 8]
tRP 8 [ 8]
tRAS 20 [ 24]
Case : Lancool k58
