the board works great with the 6 in but when i put the 12 gig in it locks up will not start at all now ive read a few bits on the forums about filling all the slots ....has anyone else experienced this and have they sorted it out as yet thanks
That is pretty unique Simon D. Congrats to you. I personally tried 4ghz , 1200mhz mem , 2400mhz uncore. Set the correct vvt ( well enough ) and everything. Did not even post for me.
What is the marketed memory specs your using. @ Them timings are pretty tight for 12GB.
McT
I am using 6 sticks of OCZ 3G1600LV6GK 8,8,8,24 @1600MHz.
I decided if I could not reach full speed on memory with a O/C, I would play with the timings I first went to 7,7,7,21 and that was stable 18hours + with prime 95.
Now testing at 6,6,6,21 27 hours + stopped, no problems so far, moving onto 6,6,6,19, 1T
I did find that if I was using IOH core set to 1.20v, I had problems in reaching 4Ghz. I found that once I dropped to 1.180v (now 1.160v) I was stable.
I can do 20x200 and 21x200 as well but I need over 1.4v on the Vcore to do so.
I found that 19x211 was better as I can run on lower Vcore.
roachyuk - Here is my bios template for the Gigabyte EX58 – UD5 at 4.0Ghz (19X211) with 12 GB (F7 bios), this may help you.
The settings below are in the MB Intelligent Tweaker (M.I.T) section of the BIOS.
Advanced CPU Features:-
CPU Clock Ratio - 19x
Intel (R) Turbo Boost Tech. - Disabled
CPU Cores Enabled - All
CPU Multi-Threading - Enabled
CPU Enhanced Halt (C1E) - Disabled
C3/C6/C7 State Support - Disabled
CPU Thermal Monitor - Disabled
CPU EIST Function - Disabled
Virtualization Technology - Enabled
Bi-Directional PROCHOT - Disabled
QPI Link Speed - x36
Uncore & QPI Features:-
Uncore Frequency - x13
Isochronous Support - Enabled
Base Clock (BCLK) Control - Enabled
BCLK Frequency (Mhz) - 211
Advanced Clock Control:-
PCI Express Frequency (Mhz) - 100
C.I.A.2 - Disabled
CPU Clock Drive - 800mv
PCI Express Clock Drive - 900mv
CPU Clock Skew - 100ps
IOH Clock Skew - 0ps
Performance Enhance - Standard
Extreme Memory Profile (X.M.P.) - Disabled
System Memory Multiplier (SPD) - 6.0
Memory Frequency – 1266 MHz
DRAM Timing Schedule (SPD) - Manual
**The following 5 options need setting for each stick of ram and are dependent on your ram**
CAS Latency Time - 6
tRCD - 6
tRP - 6
tRAS - 19
Command Rate (CMD) – 1
Advanced DRAM Features:-
I changed Row Refresh Cycle Time (tRFC) to 88, The rest are left on Auto
Load-Line Calibration - Enabled
CPU Vcore - 1.32500v
QPI/Vtt Voltage - 1.295v
IOH Core - 1.160v
DRAM Voltage - 1.60v
Advanced Voltage Control:- **Rest of settings in here on Auto**
