TURBO-CHARGING - Is the Future! :)
What a rubbish article. It makes out that a turbo was meant for boy racer cars only but the whole point of them was to make similar outputs on small engines to larger NA engines to save fuel. It looks like they have discovered the whole point of them all over again.
I thought they only reason they were not more widespreadly used was reliability?
But now they can re brand them with a green sticker on it, its all go go go jumping on the bandwagon!
You need to brush up on your history, the turbochargers first production application was on aircraft engines in the early 30's to overcome power loss at high altitudes. The first automotive uses were to improve performance of already large engines; it's use to improve overall efficiency is a relatively recent innovation.
Like this is anything new?
Smart Roadster and loads of other stuff like Nissan Figaro etc. How olds that, hmmm 20 years or something.
BBC do my **** in.
First came around in Ships iirc.
I was under the impression Supercharged plane engines are more commonplace in the 1930 - 40's?
They were, simply because the technology was better developed but that's the period when turbo's were first used in a production application.
i thought supercharging was a more efficient and smoother method?
Smoother yes, but more efficient no.
Some of the power output of your engine is wasted in driving out the exhaust gases and pushing them down the pipe. A turbo is powered by a fan in this pipe that is spun as the gasses go past, putting only a little extra load on the engine (the gasses had to go that way anyway). A supercharger is powered by a belt off the crank pulley and thus represents a constant additional load on the engine.
I wonder if high flow cats will become standard next. A little thought about fact is that cats also reduce efficiency by making it harder to push the exhaust gasses through them. If your car lives on the motorway, a de-cat is probably better for the environment than a catted car IMO.
