- 22 Nov 2007
So im going to download windows 7 pro from msdn, whats the difference between x86 and x64? Which one is better?
.That would depend on the amount of ram your system has.
If it's less than 4GB, go with the 32bit ( X86) version. otherwise, 64bit (X64) is the way forward.![]()
Q6600 is capable right?It's not entirely that simple.
The processor kinda has to be x64 capable.
So if I dig out my old 386SX you are saying I should use the 32bit version as it only has 2MB RAM![]()
Sorry, I assumed most users are on 64bit capable CPUs.
But yes, that is kinda important that it supports 64bit, lol.![]()
.So if I dig out my old 386SX you are saying I should use the 32bit version as it only has 2MB RAM![]()
