Cut corrugated steel
7 Dec 2008
Scottish Borders
Another boring thread for most of you, sorry! Following on from my last post about doing up my parents garden for them, I could use some more advice, this time with destroying a bomb shelter!
Up the back fo their garden is this mental old Anderson shelter which was put up sometime during WW2. Its main body comprises of pretty thick gauge corrugated steel sheeting which is set in a concrete base going over a meter down into the soil:( As i dont have a digger to hand i'm going to have to try and cut the steel around the base then just cover it over with soil.
Looking for advice on what would be the best way to cut this steel sheeting? My first thought was to use an angle grinder but as the corrugations are so deep it would be pretty difficult. Reckon a powerful jigsaw with a metal cutting blade would be up to the job?
cheers!
Haha good idea. Plus some of the creatures i've found in ther so far are far more terrifying than anything a game developer could come up with!
Those hand saws look pretty good. Will have a look into costs.
Fenris, it has to go as its rusted through and my old man already has 3 sheds in the garden and a greenhouse full of rubbish!
chop off the roof with one of the tools suggested then smash up the concrete don't burry it! Higher a pneumatic drill or go old school with a heavy sledge.
My jigsaw (a Makita) can cut through up to 12mm metal, but then its an expensive one. Most can indeed cut metal, but you need a good saw bit, and a powerful motor.
Just founf one of those electric hand saw thingys in his shed. Does the job although very slowly. A decent one with a better motor should get it done. Failing that i'll be filling the thing with black poweder and lighting a match!
