I think i have the Thermalright Ultra-120 Extreme but it just big and don't look so good when I look into my case on my desk next to me.
It shouldn't really matter what it looks like unless you are a gay or a woman - It's the performance that matters to be perfectly honest.
I would like it as I look in my case and see a huge cpu cooler lol, it just looks narsty, and i have a antec 902 case.
Is there any nice air cooling blocks then for around the same price? that will fit the amd 902 AMD Phenom II 940? and will fit the i5 and i7 as i will upgrade soon.
The TT is quite nice to look at in a 902 case
http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-TQ&groupid=701&catid=57&subcat=1395
no support for 1156 as yet though
Iirc on amd setups the TRUE bracket only allows you to mount the cooler facing the top of the case, this is fine in a case that has a top fan set as exhaust, you say you will be upgrading to possibly i5/i7, in this case youll need the appropriate bolt thru kit for the TRUE theese will allow the cooler to be mounted so that it pushes air to the rear case exhaust fan.another thing the tru in a antec 902, what's the best way to have it?
any news on if they will make it support it? and is it any good?
