What Motherboard for i5 750 with 8GB RAM
5 Oct 2004
Notts
Looking for a decent spec board for an i5 750 with 8GB RAM.
Must have RAID, SPDIF, Stable overclocker..
Not worried about XFire.
It also depends if you don't have problem with SATA port placement, and it seems UD4 sold in UK is in reality a UD4P (UD4 should not have dual LAN, only UD4P and higher models).
Can't see the SATA Ports being a problem on the UD3. I do like the flat type but not sure it's worth the cost.
Gigibyte or Asus.. Decisions decisions!
Reason for prefering the ASUS boards?
In the two price ranges covered, I think that all things considered the Asus offerings just have the edge over those from Gigabyte, however, when you go to the top end and compare the Asus P7P55D Deluxe and Gigabyte GA UD5 I would choose the Gigabyte and indeed that is the board that I bought and use with an 860...but you certainly would be more than happy with the Gigabyte GA P55 UD(3)R/(4)P
I guess it boils down to which one I like the look of the most. The GB and ASUS boards all look full stocked with features.
Will wait for tomorrows TWO and see if they're listed.
