No they aren't. 4890 is quicker than a 5770/5750 but not the other 5 series cards.....
no it's not. It vents the heat into the case. One of the reasons I sold mine.
No, the loaded energy consumption is not close to a 48xx ...that's a difference of 65W which is quite significant.
If i was thinking 5850 prices.
I`d be heading toward Xfire 2 X5770 if my mboard supported it.
You can get 2 x HD5770`s for £220 now.
Or, buy one, and get another in the new year which likely (hopefully) will be cheaper..
That`s what i`ll be doing.
3) Agreed 65w is significant in terms of pc cards. But not in terms of heating a room.
you are buying a pc component, who cares about 'in terms of heating a room'
1) Oops one too many X's
2) Nope - you're still wrong. I still have mine and nearly all of the heat is vented outside. Quite a nice breeze from the vents on the backplate.
