Will there be a lash back against touch screen phones?
daz
daz
18 Oct 2002
Bucks
Just been thinking about this. Touch screen phones are really good for a few tasks, but for others they can be incredibly tedious and battery life suffers against non-touch screen phones. Will touch screens get to the point where they're so good, we'll forget about using keys... or will people "serious" about email etc on their phone always use a phone with a keypad?
12 Feb 2007
South Shields
yeah and what happens when the touch screen stops working??
:confused:
What happens when a button stops working?
Same problem.
There will be both sides of the market. I have a Nokia 5800 and happily get 4-5 days battery life from it. Mostly its never used for calls, usually texts. I have larger hands than most and cannot use most button phones now since they have shrunk the buttons to get in a bigger screen, I cannot even use a blackberry. The buttons are way to small and far too close together.
27 Nov 2008
Inherently buttons are more robust and simple, with touch screen you have a lot of things that can go wrong, software might have bugs in it and what if the screen gets cracked, more chance of that happening. I had a Sony Ericsson w960i and the touch screen was always intermittant, software/firmware problem.
Caporegime
25 Jul 2005
Canada
I think we will move back slightly in the future, there are certain things that do need keys, however keypads as such I think will become less and less popular.
For example keys on the side of phones should increase (both the iPhone and the Touch HD don't have enough buttons on the side, only volume) if they are to be used as music/camera devices. At the moment it's really only volume keys that are there but after having various SE K*** phones going to a phone you have to take out of your pocket and press the screen to pause is a pain, same with taking photos by pressing the touch screen.
One positive I can see about touch screen phones is the fact you can make them weather/water proof much easier, due to the lack of buttons and only entry post being the battery cover. In the past typing on a weatherproof devices keypad was a pain, now with touch screens it won't be any different.
Caporegime
25 Jul 2005
Canada
27 Nov 2008
I think gestures are actually a bit of a phase, it's all very well gesturing but if your phone is in your pocket you can't really shake it to change songs/skip tracks etc. If it's sensitive enough to do that then it will skip while you walk...
LOL :D
Very good I like it, imagine what you would look like in the street
30 Apr 2006
London
Touch screen phones + qwerty keyboards is where it's at ;)
+3
What are my choice these days?
I basically want an iphone with a slide out keyboard, i have an MDA 2 but the screen is a bit small and it's quite bulky
EDIT - Looks like The HTC Touch Pro2 fits the bill
29 Jul 2004
Esher
Ahh the phone that put me off Sony Ericssons for life. What a crap phone, I remember my touch screen would just stop working and wherever you pressed on the screen it would register that you pressed the top right hand corner which happened to be task manager. Eventually, the phone would just start working normally. Very strange.
Will probably not get a SE phone for a long time, bought a Nokia 5800 (was really worried about how the touch screen was going to be) but this it has been a brilliant phone!
