We have 4 fireplaces in our house and when we bought the place the surveyor confirmed that they all need to have a vent added to prevent damp.
So yes, it should I would think you do need it vented.
mjd is correct. If no vent is installed then your likely to get damp patches at some point on the chimney breast, if not downstairs then upstairs. Also you may get 'Tar bleeds' from when there used to be an open fire in the fireplace many years back, these are black stains on wall and are very difficult to cover up even with special paints for the job. Best place is a small plastic slide vent in the lower section of the plaster-board close to floor.
