my chipset is, helpfully, underneath the graphics card and the fan on the heat sink that came with the MB may be on the way out - its a special fan that sits in a recessed heatsink so i doubt i could cut a new one up to fit it.
so, are there any low profile heatsinks with recessed fans out there? i don't know the exact measurements but it can't be much higher than 10mm.
i haven't had much luck finding any.
