Noob wanting to install Ubuntu on netbook
9 Jan 2005
Stoke-On-Trent
I've always wanted to try Linux but always been a little scared of it in case I could net get to grips with it. I thought bugger it and I found Ubuntu have a version of Linux specially for netbooks. Is that version good for a novice and will it run fine on my Acer Aspire One netbook?
I'm going to try and find drivers now and watch some videos on how to use Linux on Youtube. Can I learn much by just playing around with the OS? I think that's how I learned most things with Windows.
7 Jan 2007
Sussex, UK
You shouldn't have to install drivers as they already should be there! Are you referring to Ubuntu netbook remix or the LPIA (atom optimized version)?
I only asdk as I just bought my 1st netbook in town yesterday, got a Toshiba NB100 for £150 new, is it a good deal? Anyway...
I think the netbook reflux version should be optimised for netbooks, so should work out of the box.
Just back up all your data on your netbook before you start playing!
8 Mar 2006
Near Winchester
Ubuntu netbook remix contains all the drivers for the Aspitre one, you will not need to install any drivers after installing the OS, this is the way linux tries to operate, and these days Ubuntu manage it on about 75% of machines.
It's relatively easy to use, you can probably manage without dipping into the command line. And the UI is very good at not wasting space on the small screen.
daz
daz
18 Oct 2002
Bucks
Ubuntu Netbook Remix is nice but I think it's a bit heavyweight still for my Acer One. Changed the window manager from Metacity to openbox which was a big performance improvement, but I think I might look to moving from Ubuntu to crunchbang or something similarly stripped down.
15 Jun 2004
Yay I have it installed but installing flash10 is a pain. I keep getting this message
Error: Dependency is not satisfiable: libnspr4-dev
I downloaded Ubuntu version too.
are you installing through the package manager or did you download flash?
If you downloaded it, then try installing "ubuntu-restricted-extras" through add/remove programs in the applications menu. That will pull down flash, msfonts and loads of other useful stuff. (though this might still be flash 9)
If flash 10 (not 9) is important, then try looking in synaptic for the lib you're missing (system->administration->synaptic package manager)
OP
9 Jan 2005
Stoke-On-Trent
I downloaded
(libnspr4-dev_4.7.5-0ubuntu0.9.04.1_i386.deb) and installed it. Ubuntu then did some updates. After doing all that (install_flash_player_10_linux.deb) installed fine. I assumed I was missing a needed file (libnspr4-dev) and downloading it appears to have worked. :)
22 Sep 2009
Leicester
I always use terminal to install my packages/apps, but when I first started out I used the package manager because its soooooo much easier. The only real advantage of terminal is it stores the source files on the PC, where as package manager only makes them temp, so if you remove you'll need to re-download.
