Upgrade from 4550 to 4650
8 Jan 2009
Northern Ireland
Hi is it worth upgrading from the low profile 4550 to the low profile 4650, I use the 4550 now, and I was wondering if it's worth it. Thanks :confused:
AMD would probably release 55** - 56** series cards soon, which should be low profile. I would wait for them as there is not much performance boost from teh 4550 to the 4650. But then again, it depends on what you need it for.
Would be nice if they did, but i use the present card for gaming. With having an slimline system, there's not a lot of choice out there.
The 5500's ,5600's aren't due till Q1.
