A while ago I posted about wanting a new case I had a long list of features that I wanted but I think my budget was a bit tight £120, and nothing wooed me
My spec has since changed and as such so have my needs. Features that I'm looking for..
If anything else comes up I'll let you know
My budget for this is £200
Or if you think that changing some internal parts of my current case, Antec 900, is more feasible then let me know. The case is all stock cooling, so I've not changed any fans or hdd cages, which might be something for me to look at, I'm not sure if I'm honest.
But I've got some Akasa Vortexx's on my 4850's and I find them quite noisy even at 7v. I did have a Accelero S1 with a Xilence Red Wing and that was silent but when I added the 2nd 4850 there wasn't space for it, the only other thing I could do is run them passively but then it might run a little hot and I'm trying to get temps down. I've got a thermalright Ultra on my Quad with a Akasa Smokey and that seems to be just fine. Other places I may need to look at is PSU fan, the Coolermaster 620W fan is a bit loud for my liking. And the lack of anti-vibration on the HDD means they're pretty loud. So I could replace the stock cages with one of those lian li ones, but I'd still need to replace the fans on those with new quieter ones.
Before you say anything, yes I am a silence freak!
Thanks in advance for any help.
- Removable motherboard tray (optional)
- Good/Excellent cooling
- Space for a full size motherboard
- Anti-vibration for the HDD
- Sound proofing
- Enough room for crossfire cards
