My new Raven 2
Looks very nice...I have been umming and arring about a new case and may well look into getting one of these (great concept) but for a while i will keep my poor old sonata for now as skint from buying new parts :)...
Someone with a DVI dongle might be stuck :p Not sure about the top panel, seems like a pain if you want to plug another usb cable in.
The only thing that would concern me with this case is the bend radius of the cables with the top cover on-do they wut any strain on the mobo?
No, none at all.
The access to the 'back' of the motherboard is much improved over the Raven 1.
It is set deep, and the top cover is quite high. You can easily stick a usb dongle in there and have the cover on, or indeed use a vga-dvi adaptor.
Plugging in an extra usb cable to the back is easier than with a conventional case design, especially in 'pc under the desk' scenarios, no need to pull the case forward and get on your knees to clamber behind the case.
