Hi All,
I just set up my new Lian Li tower and put in the following LCD Panel
http://www.overclockers.co.uk/showproduct.php?prodid=CM-006-LL
Turned on the PC and everything works fine BUT if i have the 2 case fans plugged into the Panel the LED lights on the fans constantly flash. The manual that comes with this panel is vague at best so i'm wondering if anyone has any ideas?
http://www.lian-li.com/v2/tw/product/upload/manual/C50.TR-30.00.pdf
I'm wondering if it's because i've not got a 3rd fan plugged in but then again there is no alarm going off to say there is a problem
Any thoughts would be great
Baffled Chris
Baffled Chris
