Oh for christs sake... Assuming I have NO other copy of Windows, no, lets assume I don't even have another computerto "upgrade"- If I have a brand new Hard-Drive (For my new PC) would I be able to buy this student W7 deal and install it onto that hard-drive or not?
If you do not have either a Retail or an OEM license of either Windows XP or Windows Vista, I'm afraid you do not qualify for an Upgrade license of Windows 7.
Hmm, so, I have a Windows XP Upgrade Edition disc, would I be able to use this at all? There won't actually be an OS installed on my new hard-drive, but I Have this XP disc.
I'm afraid you don't qualify for an Upgrade license of Windows 7 since as stated above, you need either a Retail or an OEM license of Windows XP or Windows Vista.
I know this must have been asked quite a few times, but can I confirm that the student Upgrade edition is OEM rather than retail? i.e. it's locked to the motherboard you first install and activate it on.
I would also like to know with the student version of Pro if it genuinely is retail, in terms of future activation having changed your components (motherboard)....will that work?
The Windows 7 Home Premium and Professional editions that you can purchase for £30, they are Upgrade licenses which means you need to have a Retail or an OEM license of either Windows XP or Windows Vista to qualify for this offer.
A Windows Retail license means that you can move Windows from one machine to another as long as you remove it from the first machine. An OEM license is slightly different in that once it is installed on a machine, it cannot be transferred from one system to another. Though, you can change any hardware component apart from the motherboard and you will still be correctly licensed.
Regarding what happens with a Windows 7 Upgrade license and the sorts of restrictions you're bound by. If you have a Retail license of Windows XP or Windows Vista and you then purchase a Windows 7 Upgrade license, it
effectively becomes a Windows 7 Retail license. You will be able to change the motherboard of that particular system that you have Windows 7 installed on and still be correctly licensed.
Now, lets say for instance you have an OEM license of Windows XP or Windows Vista. If you purchase the Windows 7 Upgrade license, you then
effectively have a Windows 7 OEM license which means you will not be able to change the motherboard of that particular system, just as if you hadn't installed Windows 7 in the first place and left Windows Vista in place.
Though, despite what I have just said above about what happens when you upgrade from an OEM license of either Windows XP or Windows Vista to Windows 7 using a Upgrade license, it only applies to machines in which you upgraded to Windows 7 from an OEM license of either Windows XP or Windows Vista. An Upgrade license is transferable which means you're still perfectly entitled to remove the copy of Windows 7 from the existing machine and then install it on a new machine, providing the new machine has a legitimate copy of a Retail or an OEM license of either Windows XP or Windows Vista.
just one question is the upgrade student version motherboard locked like the oem used to be?
What I have said directly above should answer your question.
