Whats the best 3 x 120mm rad?
20 Apr 2003
Gloucestershire
Hi All,
Starting to feel the urge to do my first water cooled rig. I have the Silverstone TJ10 case and have seen several builds where people have fitted a triple rad very neatly in the top.
Anyone here done this in a TJ10 or TJ9?
Ta,
E-I
Thermochill or feser, with the thick black ice one very closely following. Feser have the advantage of using G1/4" threads, thermochill are probably cheaper and British made.
This is assuming a definition of best related to performance not to performance / cost.
edit: forgot xspc, it'll also come in shortly after thermochill and feser
Everything else uses them, mainly. So you can use the same barbs everywhere, instead of needing G3/8" ones or adapters for the radiator and G1/4" elsewhere. It's not a big issue if you don't mind adapters / can find appropriate barbs with that thread on them.
XSPC reservoirs use an M20 thread for the fillport, M20 to G1/4" adapters also exist.
The new Thermochills (since about March 2009) are G1/4 and 15mm fan spacing. I believe Thermochill is now owned by XSPC, although that could be incorrect.
