The New Cases Gallery
The Akasa All In One, was it a straightforward install? I took one look at the bag of cables that came with mine and put it straight back in its box.
tbh i took it out just after this pic was taken, it worked fine at first but the card reader was all i wanted it for and it seems to have died and i cant fathom how to get it back on so its gone now. bit rubbish tbh. half the cables i didnt use, gonna look at a dedicated card reader now.
200mm fan front and top
That sounds very encouraging! Thanks.
Don't worry guys, the stock intel cooler will be replaced soon. Probably Corsair's H50. Is a bit of a struggle keeping stuff tidy in this tiny case, but i still love it.
Finally finished my SFF build in a lian li V351b had to drill all the internals out and modify it to fit the rad then re-rivet it all back in but got there in the end.
really cant wait til next month, getin 2 5850s (well first one this coming montht then another next month. il post some pics in 2 week
Is that the Black Ice GT Stealth 240 in the front as i know most rads are either too big or too thick but that looks like its fits perfectly
Also what spec is your water need some ideas for the future :D
Cracking build:)
Looks really nice, Craig. Is that a 120.2 rad in the front? Have you got an optical drive stealthed in there too?
It is a Black Ice Stealth GT lite 120.2 yes was a bit of a tricky one to get in there. Note it has to be the lite version i have the normal GT stealth sat in a box at home after buying it to find it didnt fit :P
I opted for an external Samsung USB2 optical DVDRW that i run from the bottom of one of my Dell 2408WFP screens, i simply use the optical drive so little other than installing games i decided i could do without the massive 51/4" drive.
Cracking build:)
Yeah posted the rad above i had to aquire it from germany tho couldnt find anywere in the UK stocking it.
Im using the XSPC DDC dual bay res for a single pump, one 18w DDC, Black ice Stealth GT 240 lite, Swiftech GTZ, and Swiftch NBMAX block with bitspower compression fittings and a couple of other bitspower fittings.
New Overclocked i7 Build.
The specs are...
- Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz overclocked to 4.00GHz
- Noctua NH-U12P SE1366 CPU Cooler (Socket LGA1366) with 2 Noctua NF-P12 120mm Fans running in a 'Push Pull' config
- Gigabyte EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
- Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel Memory
- Asus GTX285 1024MB GDDR Video Card
- Creative X-Fi Xtreme Musc Sound Card
- Crucial M225 128GB Solid State Hard Disk for Windows
- 2x 500GB Hard drives for storage
- Corsair HX 850w Modular PSU
- Asus DVD Burner
- Lian Li PC-7FW
- Windows 7 Ultimate Edition
