Puncture (can hear air hissing out)
Don
21 Oct 2002
Parts Unknown
After a long motorway run today, I noticed the car starting to pull to the left slightly, luckily, petrol station was 1/2 mile ahead, so pulled in to find my front left tyre at 15psi :o
Was only 13 miles, so drove the rest of the way home, can hear it hissing out still.
I assume it's a good idea to leave it with a block under the jack point for that side?? Can any kind of repair be done on tyres? Or shall I just order a new set of 4 http://www.camskill.co.uk/products.php?plid=m4b0s288p15203, been wanting to replace my T1R's since I got the car..
It can be likely be repaired providing whatever has punctured it hasn't done any damage to the carcass and it's not close to the sidewall.
Assuming it's not the valve, the tyre can be repaired if the puncture is in the tread pattern. If it's in (or near) the sidewall then the tyre is scrap.
If you have alloys they may be excessively corroded and this might be stopping the bead from sitting properly.
The last time I heard hissing I had run over glass. There was a small shard in the centre of the tyre but it couldn't be repaired (had lots of nail repairs done at the same place) :(
Considered Kumho KU31? I just tried them on the EK9, i'm impressed. Do a search for KU31 on itr-dc2, there's a few that've tried them.
£30 each for 195/50/15.
Thanks Tim, went for KU31 in that size after reading good things about them on itr-dc2, especially that guy who tested the 55's and 50's in the same day.
Was £155 ish fitted.
Haven't driven a fast car on brand new tyres before, had a bit of a controlled slide on the first roundabout :o
Will let them 'break in' a few hundred miles before testing them
They don't really suit the Integra, they had great wet grip, but felt a bit 'bendy' when cornering at speed
I run a set of these on one of my cars and they are pretty good.
However, I think the Vredstein Sportrac 3 is a better tyre and they come in at just over a tenner more than the Kumho.
No worries, its normally Matt82 recommending them:p They're superb for the price, I can make them screech a bit though when pushing..
Cheers, the Puma boys seem to love them, different cars suit different tyres i guess !
They have ass sidewalls:(
