- 12 May 2005
Hey,
A few quick questions if you could help.
I'm completely new to using a dremel (I don't own one) and want to purchase one and a soldering iron. The iron will be used for basic electrical wiring, nothing major / intricate. Basically I want something to replace the "wrap the wires around the thing with tape and hope for the best" approach.
As for the dremel, I want it to start doing some case mods so I guess it needs to cut thin metal / plastics? Can they do that okay, if so is there any particular model to look out for?
Not really looking to spend a lot if I'm honest as they won't be used a lot, more for the odd job here and there. Any suggestions / models / things to look out for?
Obviously don't link to the OCUK competitors, so would be easier to just mention brands / models.
