MSI Afterburner..
8 Jan 2009
North East
Hi all, just started using MSI Afterburner to overclock my 5850, but i cant get the clock speed slider to go past 775mhz.
Any ideas how to push it further? As soon as i click apply it jumps back down to 775
Cheers
ok cheers mate, fist time flashing a gpu hopefully its easy as flashing the motherboards bios...
ps, does it matter im using sapphire card - i assume it doesnt as its just the brand but want to be sure.
ok, i have just formatted a usb stick, will have a read before i rush into it, dont want to screw anything up.
thanks all...
ps, looks complicated, but i want to to push the gpu!
You have the usb drive at the top of the 'hard disk boot priority' menu? Do you have an F12 selectable boot menu?
i have it at top but which one do i use out of these:
LS120, ZIP, USB-FDD, USB-ZIP, USB-CDROM or USB-HDD?
Do not use the BIOS from my rapidshare though, it's for the 5870!
I havn't, i used one from the link fornowagain provided that ended in .A11 which i renamed to .rom
When i follow your tutorial, and the BOOTFILES are made with the HP usb dos program, should i be seen these files on the dongle, because after the boot disk has been made im seeing nothing on the usb.
CHeers
ok will have a look again, but when i make the dos thing with the HP USB Disk Storage Format Tool i see no files on my usb.
Well i think i did it ok, backed it up, flashed it, but when i went back into windows its asking for me to install the drivers again - is this normal?
never mind, rebooted again, windows picked up the drivers.
gpu-z says my vendor is msi even though the card is sapphire, nothing to worry about is it?
afterburner let me up the clocks past 775 now though :)
what clock speeds are you lot getting, or are you using 5870's?
cheers everyone!
