- 8 May 2009
motherboard bios is updated and for some reason overclock doesnt work tried everthing even massive cooler
The 680i motherboards use a 4 pin Molex power socket to help power the GPU cards....Have you got that plugged in ???um foxconn 680i
that wouldn't be too wise if it's not working at stock settings
you are on stock settings aren't you?
He's running a Q6600 @ 2.5Ghz![]()
Didn't know what a Q6600 runs at stock, I suggest removing all overclocks then trying.
On this 680i board in the picture below it the black 4 pin Molex socket above the blue IDE socket
