5770 Crossfire PSU requirement
8 Jan 2007
I have a 5770 and a Q6600 clocked at 3ghz, 4 gig ram, 2 1TB hdd's ... I was tihnking maybe in 6 months ill buy another 5770 to crun in CF...
I currently have a corsair 620w modular psu - will that be enough to run two cards in CF comfortably?
On the box it says 600watt recomended for CF but obviously you can never really trust the boxres 100% so does any1 have any additional info/experiences?
Ta
620watt is more than enough. The 5770 peaks 108watts so Xfire will only use 15% more than a single 5870. A good 500watt would be plenty, let alone a 620watt psu.
How do you mean? Different clock speeds? Mine is overclocked at the moment - i would just need to reset it to stock speeds when i add another card yes?
Usually the cards run at the speed of the slowest card, I assume it is the same for OC'ed cards.
