** Fractal Design Cooling Fans **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Fractal Design 140mm Silent Cooling Fan @ £11.99 inc VAT *** ***
Fractal Design "Silent Series" is a full range of silent case fans. The fans has been specifically developed to deliver sufficient airflow and still keep a low noise level. Available in sizes from 40mm up to 140mm.
Each fan is supplied with rubber fan mounts and four fan screws.
- Fan Speed: 600 RPM
- Noise Level: 9 dBA
- Air Flow: 39 CFM
- 3 pin connector
- 2 Year Warranty
Only £11.99 inc VAT.
ORDER NOW
*** *** Fractal Design 120mm Silent Cooling Fan @ £9.99 inc VAT *** ***
- Fan Speed: 1000 RPM
- Noise Level: 15 dBA
- Air Flow: 38.3 CFM
- 3 pin connector
- 2 Year Warranty
Only £9.99 inc VAT.
ORDER NOW
*** *** Fractal Design 80mm Silent Cooling Fan @ £7.99 inc VAT *** ***
- Fan Speed: 1400 RPM
- Noise Level: 11 dBA
- Air Flow: 16 CFM
- 3 pin connector
- 2 Year Warranty
Only £7.99 inc VAT.
ORDER NOW
*** *** Fractal Design 60mm Silent Cooling Fan @ £6.99 inc VAT *** ***
- Fan Speed: 3000 RPM
- Noise Level: 19 dBA
- Air Flow: 16.1 CFM
- 3 pin connector
- 2 Year Warranty
Only £6.99 inc VAT.
ORDER NOW
*** *** Fractal Design 50mm Silent Cooling Fan @ £6.99 inc VAT *** ***
- Fan Speed: 3500 RPM
- 3 pin connector
- 2 Year Warranty
Only £6.99 inc VAT.
ORDER NOW
*** *** Fractal Design 40mm Silent Cooling Fan @ £6.99 inc VAT *** ***
- 3 pin connector
- 2 Year Warranty
Only £6.99 inc VAT.
ORDER NOW
Would be niec of someone could put the CFM on each fan listed on the site.
FYI Slackworth from Fractuals website
# Silent Series 40mm-----3.8CFM
# Silent Series 50mm-----7.6CFM
# Silent Series 60mm-----16.1CFM
# Silent Series 80mm-----16CFM
# Silent Series 92mm-----24.1CFM
# Silent Series 120mm----38.3CFM
# Silent Series 140mm----39CFM
Done.
